Old 08-10-2018, 02:19 PM
Morris Morris is offline
Cobra Make, Engine: Kirkham #259
Here's where we mounted the cooler ... we take the air that is coming down the tunnel and exit the air out the cooler. work like a champ.
Here's the Brackets we made to hold the cooler and mount it on rubber Isolaters and the hole in the bottom Torsional Plates to evacuate the air coming down the tunnel.... Remember the area under the car is a Low pressure area.
Here you can see the Plumbing of the Transmission from bottom of the transmission to the filter then to the Weldon Pump, and then to the cooler then back to the transmission. I had Liberty modify my transmission so we could bring the fluid back into the Transmission at the Meeting point of the Input main shaft and the Counter Shaft where most of the heat is generated.
Morris
