Thread: Brake advice?
Old 08-11-2018, 05:43 PM
PSYCHO's Avatar
PSYCHO PSYCHO is offline
Cobra Make, Engine: FFR, GT FPV 5.4L 290kw Boss
It's been a long time but I had some dramas with the proportioning valve on a 73 mustang. After a lot of headaches I found that it was worn out. not sealing properly etc. Got it rebuilt by a "brake expert" and it was useless. The apprentice had had a go and put it together all wrong. You can buy new replacements now. Check that first.
Thanks Rob
The built in prop valve has been reconditioned by the brake shop along with the master cylinder which they pressed in a new bore sleeve which so far hasn't made much difference so I have fitted a second external prop valve unfortunately still no change but thank you for the advice mate👍
Regards Rob
