Thread: Brake advice?
Old 08-11-2018, 06:53 PM
PSYCHO's Avatar
PSYCHO PSYCHO is offline
Cobra Make, Engine: FFR, GT FPV 5.4L 290kw Boss
Originally Posted by Zedn View Post
Is the pedal easy to push down with the rear bleed nipple open? I wonder if there is a blockage in the rear line or stuck pads.
Thanks Zedn
I have had both rear callipers off the discs and pumped the pedal and I could see the pads close the gaps and stay there then reset them and refit them to the discs. I then pumped them again and could see them apply pressure to the discs it just seems to not apply enough pressure under drive. Thank you for the advice I will keep looking.
Regards Rob👍
