Thread: Brake advice?
Old 08-11-2018, 06:17 PM
PSYCHO's Avatar
PSYCHO PSYCHO is offline
Cobra Make, Engine: FFR, GT FPV 5.4L 290kw Boss
Originally Posted by Gav View Post
The problem that you have is that you need to match the master with the calipers.
It sounds like the front calipers are not getting enough fluid (cylinder too small) and the tears are doing most of the work.
Try ringing racebrakes, hoppers stoppers or a reputable brake shop near you, tell them what you have and let them make a recommendation.
Personally, Howard from race brakes ph 03 96877222 is fantastic to deal with.
Thanks for the recommendation I will give them a call Monday
I thought that a 1" bore from a large falcon would of had enough pressure to activate a standard brake setup from a fox body mustang but I will check
Cheers Gav👍
