Thread: Hi.
Old 08-21-2018, 07:37 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by t walgamuth View Post
Nothing much done this week or last. I had cataract surgery last wed. and will do the other eye today. Lots of thinking.
In my receipts from the PO there is a receipt for raising the car 1" on its suspension "to improve streetability" or some such. The truth, I believe, is that it was raised to keep it off the tires because they stick out too far. So I am looking for wheels with more backspacing so I can lower the car and the tires will tuck up inside the fender like they should.
The problem is finding wheels that fit 5 on 5" bolt patterns that will carry the tires and not be too heavy. I found some lovely wheels but they are for 5 on 4.75" bolt patterns.
I may have the studs relocated in the hub to fit the 5 on 4.75" pattern that is common with Corvettes of certain years and look to have backsets which will be an improvment to what I have.
I also noted that the lower a arms on front are not parallel to the ground. I believe I'll have to relocate the front down so they will be parallel.
The rear I am trying to figure out but I think lowering it will settle the car too.
Why do they "need" to be parallel?
They may be closer to parallel to the ground when you lower it after the wheel swap.
Gary
