Old 08-24-2018, 12:29 AM
rsk289's Avatar
rsk289 rsk289 is offline
Cobra Make, Engine: 289 leafspring, r/p
Just a tip: hold the sender next to the tank with the mounting flange as close as you can to the installed angle, and check that the float arm can move through its full arc without hitting any obstacles. Check inside the tank for baffles, too. And be sure to mount it in the correct orientation so it doesn't hit the sides!
Sounds obvious, but we've all been there...
Roger
