Old 08-30-2018, 12:27 PM
vntgspd's Avatar
vntgspd vntgspd is offline
Cobra Make, Engine: ERA #347
Originally Posted by 66gtk View Post
I've been in your shoes before. I had to take a dremel and carefully sand away the portion of the dash (backside) to recess it enough to hold the nut down on the front. I found a way to do this on my installed dash by putting a sanding disk backwards on the the dremel after I pushed the dremel through the hole and then apply a pulling pressure as I sanded away material on the backside.
Genius! I haven't had to do that but I will remember the trick.
