Old 09-03-2018, 05:20 PM
tortuga tortuga is offline
Default Second on the stover locknuts
We use a "stover" nut https://en.wikipedia.org/wiki/Distorted_thread_locknut
A Nylock will not work as the heat melts the nylon and split lock washers fail with the heat cycling (takes the temper out of the steel) and allow the nut to loosen with the vibration. As this is a "tension" rather than "shear" application, a grade 5 or better will work although some bolts handle the heat cycling better than others.
You have to drive the all the way on, and to remove them you will likely snap the bolt...BUT they will NOT come off.
Steve H
SPF 1764
Superformance 1764
Built 427W
Aiken SC USA
