Thread: Headlight issue
Old 09-04-2018, 12:15 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Blas View Post
The latching relay will click when a ground is MOMMENTARILY sent to it via the switch on the stalk. If you manually hold a ground wire to it for and extended period you fry it.
Blas
And why does that occur?
Sounds like a design fault.
Any relay I know of can be setup as a latch, and the operate momentary pulse width (even on permanent) makes no difference.
Gary
