Old 09-05-2018, 07:12 AM
Grubby's Avatar
Grubby Grubby is offline
Cobra Make, Engine: ERA 838
Mark,
I ended up making my own side curtains.
I found a super deal on side windows for an unknown type of kit. They appeared to be OEM type design in really rough shape. In addition, I looked closely at the Europaspares frames - they looked really good.
The windows were used as a example to build my own. The two most difficult parts of the build were bending a radius with the aluminum channel that is used at the back of the window and making the vinyl trim.
If you are good with you hands and can get a good look at a pair of windows then go for it. I probably had less than $200 in them and they looked fantastic.
While I was at it I built a unit to hold the windows together in the trunk. It kept them from getting damaged when not in the doors.
I can't seem to find any pictures right now. If you want to discuss, I am glad to walk you thru the process and the types of raw materials needed and where to get them.
John
