Old 09-12-2018, 12:46 PM
tocheck's Avatar
tocheck tocheck is offline
Cobra Make, Engine: Backdraft, small block
Originally Posted by Quentin Z View Post
No track, but had the same issue, rears locked up first. I have an older car and decided to replace the master cyl and add a proportioning valve at the same time. Interestingly, the replacement master cyl seemed to have different bore sizes front and rear, while the old one was nearly the same. Not sure if that's why, but the new cylinder works much better, and I never touched the proportioning valve, although its there if I need it.
Thanks for the info. Any chance you still have the part number of the master cylinder you bought? Wondering if it is the same as the one suggested by Spdbrake.
