Old 06-02-2002, 11:16 PM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
Fel Pro.. they are like a black rubberized material. I love mine.. on and off in a snap, Kragen, Schucks and Checker all have them on the shelf.. Pep boys too probably.. Keep it simple..
As for stopping the leak described above.. I find the problem is two fold compounded by the FE valve cover needing at least one more bolt.. What I found is there are generally two leaks.. one at the manifold/head seal the second at either the low point where the intake manifold should stop, but is too low, or (in my case) where the intake manifold gasket sticks up into the valve cover gasket and is too high..
For the first condition I actually ran a small bead of RTV in the channel on the inside if the intake/head seam of about 1" from the valve cover gaset... I was getting a leak through the very small gap in below the valve cover (between the head and the manifold).. Don't get wild with the silicone and let it glob up.. it could break off if you over apply it.
The second area was right at the joint at the head and intake. My intake manifold gasket was actually sticking up at this point and should have been trimmed prior to final assembly, but wasn't.. (I didn't build the engine) The gasket has a steel inner liner so cutting it would cause more damage than it would be worth.. Replacing the gaskets would be a good idea but I have done FE intakes before and it is a chore..
What I did was to apply a bit of RTV to the protruding intake gasket on the valve cover seating area.. smooth it down flat as if to make the transition less severe and lessening the job the valve cover has to do, let it DRY.. This allows you to remove the valve cover next time..
It worked for me.. I use to have a small puddle at the front of the engine by the timing cover after as little as 20 min. of driving.. Not any more.
Regards,
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
