Old 09-20-2018, 05:55 PM
Texasdoc's Avatar
Texasdoc Texasdoc is offline
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
Originally Posted by fastd View Post
no disrepect to carbs, but Holley Sniper
Tried that too. Actually it was the Holley HP EFI. Ended up with the carb.
I had more trouble with the EFI system but despite over a year of programming, timing, replacing O2 sensors at $120 each, etc, I was still left on the side of the road more times than I care to count. The carb may run rich, lean, or rough, but it rarely fails outright once running.
Brent, I was trying to make sure the OP knew he could trust you. I stated that you would stand up and fix anything that might go wrong. You offered to take it back and fix it. I just took it as an opportunity to learn. My warning to the OP is just to know that nothing is just bolt on with these cars.
To all reading this: Just to be clear: I still recommend Brent. He will stand behind everything he does.
