Old 09-22-2018, 04:31 AM
Ron61's Avatar
Ron61 Ron61 is offline
I don't know if you would like this idea or not, but on my first Cobra when I had to drop the tank to get to the sending unit I cut a door in the trunk floor above the unit that was large enough to open and get it out without any problem. I had my trunk carpeted so you couldn't even see the door unless you knew where to look and all I had to do was remove two screws to gain access. It came in very handy as I had to get in there to replace one of the rubber fuel lines that started leaking and instead of spending all that time removing the tank to get to it I had it done in about 15 minutes.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
