Thread: Coil weak spark
Old 09-28-2018, 04:19 AM
Ron61's Avatar
Ron61 Ron61 is offline
Marco,
I am sure that you have already checked this but did you look inside the distributor cap to see if the terminals are worn or black with carbon dust? Also check the coil wire to see if it has gained a lot of resistance. If it is the resistor you would probably be ahead to just get a new one and put it in. I got one at NAPA a few years ago after I measured the resistance and found out what the ohms should be. Best of luck with getting it sorted out soon.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
