Thread: Coil weak spark
Old 09-28-2018, 11:15 AM
Ron61's Avatar
Ron61 Ron61 is offline
Marco,
You can check the resistance of any resistor or resistor wire with a volt/ohm meter. The coil itself will have two resistances. One for the primary winding and one for the secondary winding, but if you have a weak spark getting to the coil then the problem is back toward the distributor and ignition system.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
