Old 09-28-2018, 01:02 PM
rads42 rads42 is offline
Cobra Make, Engine: ERA #720
Originally Posted by jhv48 View Post
Mechanical gauges act just like a thermometer and should read the correct temp if the sensor is placed in a bowl of boiling water. Not dependent on ignition key or a ground.
Did this just happen or has it been like this forever? Usually when the hollow capillary tube of a mechanical gauge is breached, the gauge ceases to function altogether.
Are you sure the gauges are mechanical? There would be a protective wire sleeve wound around the entire capillary tube from the sensor to the gauge. If all you have is a wire to the gauge from the sensor, then you have electric gauges and the sensor will have to be grounded and the ignition switch on in order to test it.
Did you use some sort of sealer or tape to seal the sensor when it was installed in the engine? Sometimes that will inhibit a proper ground but then the gauge either works or it doesn’t. Your particular problem is a head scratcher. Both temp gauges failing at the same time is highly suspect.
I bought the car like this so I don't know how long it's been going on. The gauges are definitely mechanical and have the wire sleeve over the tube. I was stumped that the gauge didn't read and I know the key position shouldn't make any difference but I was so puzzled that it didn't read anything so putting the key on was my only guess.
I'm in agreement that both gauges reading incorrectly the same is almost impossible hence my call for help. This has to be something simple I'm missing.
