Old 10-09-2018, 08:44 AM
davids2toys's Avatar
davids2toys davids2toys is offline
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Any access is better than what you have to do right now for an ERA outboard braked rear with the emergency brake. To grease the front u-joint, you have to rotate the drive shaft to just the right spot, release the e-brake, and the little brass circular thing slides back and gives you just enough room to get a pistol grip lube fitting up in there. No where in the manual does it tell you that you have to release the emergency brake in order to even see the zerk. It took me a while, and mostly luck, to figure that out. If the emergency brake handle is up, you don't stand a chance and it looks absolutely impossible. I now can do it pretty quickly, but I would still prefer a little lift up carpet flap, with a rubber plug under it that you pull out, and then you can lube it from the side. I can see that for complete u-joint change out you're going to have to pull the tunnel.
Don't know anything about the outboard brake setup but that front yoke grease is no picnic on the inboard brake cars either! I like the idea of a rubber plug that has carpet glued it. If done right, you would never see it
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
