Old 10-09-2018, 05:53 PM
spdbrake spdbrake is offline
Originally Posted by cycleguy55 View Post
Wix has a good filter look-up system at WIX Filters - Products Catalog Home
The standard Ford filter is a Wix 51515. When you look at its specifications you'll see the bypass valve is 8-11 PSI.
Product Specifications
Part Number: 51515
UPC Number: 765809515154
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Enhanced Cellulose
Height: 5.197 (132mm)
Outer Diameter Top: 3.661 (93mm)
Outer Diameter Bottom:
Closed:
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=6/20
Burst Pressure-PSI: 290
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
Yup Wix makes great stuff. I had that info in my 1st questions Ed above.
I use the 51515R since it has a better gpm flow rate.
Part Details
