Thread: 1.1g barrier?
Old 10-19-2018, 03:23 PM
Grey 65's Avatar
Grey 65 Grey 65 is offline
Cobra Make, Engine: BDR #888, Keith Craft 408
Originally Posted by Cobra #3170 View Post
CSX 3170 will pull 1.3 G on just about any surface using Bridgestone RE71 200 UTAG tires 285/30/18 fronts and 305/30/19 rears. On good concrete we have seen over 1.4. These are not spike loads but sustained through a corner. I have not tried it on a skid pad but assume it would be similar. We also get 1.0 to 1.1 in acceleration and 1.2 braking G. We are trying a different brand this weekend will let you know if it is better. BFG Rivals pulled about .1 G less cornering and .1 G more acceleration and braking so we switched to Bridgestone three years ago. Under max G load the car lifts both front and rear inside tires slightly off the pavement like a gokart. There is a picture in my gallery of the car doing that. Cobra cornering power is helped by weight put hurt by track width. These numbers are all in the 40-65 mph range. Aerodynamics will limit high speed cornering loads unless you do what Morris has done and fix the high speed aerodynamics.
After watching that video not sure we could pull those G's on a 200 foot pad, would be fun to find out though.
My car pulls about 0.1g less than 3170 does, but still over the threshold you are asking about.
How might you ask? I normally stay in a Holiday Inn Express before racing events. That and my Backdraft has been setup as close as possible to the same setup CSX3170 runs. Bruce is kind of my unofficial crew chief. I have reaped the rewards of the countless hours of research and testing Bruce has done on his car.
Kevin......
It isn't how fast your car can go
It is how fast your car can change direction
Home of Fake Snake Racing
