I think you are correct. The original relay triggers on heat generated by current flow and since LEDs don't draw enough current the relay is not triggered. Someone here likely knows the part number for what works. I think they are usually listed on the LED supplier web site also.
Did not see the previous post. The resistor increases current draw.
Reason: Clarity
