Thread: LED help
Old 10-20-2018, 01:43 PM
marklotus marklotus is offline
Cobra Make, Engine: KMP938
Originally Posted by ffmedic86 View Post
So now thinking I can just change out the flasher relay? If so, what about the hazard relay, guessing that would need to be changed out as well. Should be able to use the same relay to replace it. Any thoughts?? Here is what I'm looking at
https://www.hipoparts.com/12v-heavy-...flasher-relay/
I don't think that flasher will work for you. I think it needs to say "for LED use" on it. I originally bought one that looked like the one you linked. It said that it was LED compatible but in the fine print it said "may require a resistor to work with LED's". It didn't flash. I should have the LED specific flasher I ordered by Wednesday and can let you know if it works.
BTW, like the originals, my car doesn't have 4-way flashers so don't know about a relay for that.
