Thread: LED help
Old 10-21-2018, 10:13 PM
krausewich krausewich is offline
Cobra Make, Engine: MidStates, 351C, 4spd, 9"
Send a message via AIM to krausewich
Originally Posted by ffmedic86 View Post
So from looking at this, I have the double round (two bulbs) on each tail light. The wiring running to them is just split at the lights. Would I need 2 resistors for each side (one resistor per bulb) or just a single resistor for each side. Then also one resistor for each front marker/blinker.
For the rears, can LEDs be run in series vs. parallel now that the draw is much less.. may only require a single resistor. Also can LEDs be used in the instance when replacing a twin filament bulb?
Good luck,
Mike.
"It's not about getting from point A to point B. It is the point"
-J. James
M. Krause
1.508.944.3368
