Thread: Starting issue
Old 10-23-2018, 02:13 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
David,
If you have a 6AL, there is not 12v at the ignition coil, there is some 480v with the engine running, since you have a CD ignition, not inductive ignition.
The coil primary terminals are more dangerous in a CD ignition.
After reading your opening statement, I wasn't surprised to see you have a MSD ignition fault.
Now, onto some testing.
Can you disconnect your mag trigger harness at the distributor, remove the coil wire from the distributor, set up the coil wire with 1/2 inch gap to ground.
Get yourself a paperclip, form a horseshoe.
Then ignition key on, bridge the mag harness that goes towards the 6AL module in rapid on/offs. Does spark jump across your 1/2 gap?
Gary
Gary
