Old 10-23-2018, 05:59 AM
jon@harrison.ne jon@harrison.ne is offline
Cobra Make, Engine: JCF supplied the body,frame,and some of the driveline-I completed it to be a very accurate 289 slabside
"Generally, all warning lamps are fed with 12v positive in parallel, the other side of each lamp is grounded by a switch, either a oil pressure switch, high engine temp switch, alternator warning lamp circuit etc."
I don't think you want to wire the alternator (charge light) to ground!
