Thread: Starting issue
Old 10-23-2018, 12:04 PM
patrickt patrickt is offline
Dave, you do not need to remove your ignition switch, the terminals are easily reachable from under the dash. But, if you feel the need to remove it, it's pretty easy to just make a "two prong" tool that fits the two slots around the switch. It just unscrews and your ignition switch is very easy to change out. I did mine about ten years ago and it was a ten minute job. That said, a "no spark" condition with the MSD box is the easiest to diagnose no start condition there is. Don't take any VOM measurements, don't jump to any conclusions, just follow these instructions: https://www.holley.com/support/troub...ng_techniques/ The hardest part is just figuring out whether you're using a white wire trigger or the purple/green trigger. It's either going to be: 1) a bad magnetic pickup; 2) a bad coil; 3) a bad MSD box; 4) a bad distributor cap/rotor; 5) a bad 12v feed to the box.
