Thread: Starting issue
Old 10-23-2018, 07:53 PM
davids2toys's Avatar
davids2toys davids2toys is offline
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Originally Posted by Gaz64 View Post
David,
If you have a 6AL, there is not 12v at the ignition coil, there is some 480v with the engine running, since you have a CD ignition, not inductive ignition.
The coil primary terminals are more dangerous in a CD ignition.
After reading your opening statement, I wasn't surprised to see you have a MSD ignition fault.
Now, onto some testing.
Can you disconnect your mag trigger harness at the distributor, remove the coil wire from the distributor, set up the coil wire with 1/2 inch gap to ground.
Get yourself a paperclip, form a horseshoe.
Then ignition key on, bridge the mag harness that goes towards the 6AL module in rapid on/offs. Does spark jump across your 1/2 gap?
Gary
Hi Gary,
Just a little over my head here.What is a CD ignition? What opening statement are you referring to? Why are you not surprised?
As far as your testing goes, it unfortunately has to wait. I am leaving for 1 week vacation Sat morning and running around all this week. No time for the Cobra until I return end of next week. I will gather research info and hit it hard when I return end of next week. I will have to get a diagram I can identify the parts you are referring to.
Thanks
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
