Thread: Starting issue
  #26 (permalink)
Old 10-25-2018, 08:44 AM
patrickt patrickt is offline
I have had faulty "locking pigtail components" before from ERA, so I wouldn't want to bet a lot that somehow it wasn't causing part of the problem. If it was me, I would just cut the two wires that are coming off the magnetic pickup, strip them back, and measure the resistance. If the resistance is back up to normal, I would leave it in there. If the resistance is bad, then I would replace it with the new one, and hard wire/solder/shrinkwrap the connection and not worry about it again until you pull the engine. For electrical cleaner, I use whatever spray cleaner I happen to have, 409, Windex, Mr. Clean, etc., then I rub the ends with a little 400 grit sandpaper, then a light wipe of dielectric grease. I use dielectric grease on anything that conducts electricity and have so for almost 50 years. Electrical connections, plug wires, distributor terminals, the rotor tip, everything.
