10-25-2018, 09:46 AM
ct
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Originally Posted by patrickt
Yes, you can just use twist caps to put the wires back together. That's no big deal. If all is working properly, and the cap and rotor are installed, when you disconnect your coil wire, and then place the end a half inch away from the block, or use a spark tester, and then crank the engine you should see multiple sparks flying out as you crank. If the magnetic pickup is bad, or if you have sheared your pin, you will not see those sparks when you crank but you will still pass the "paper clip" test that bypasses the magnetic pickup. The paper clip test basically tests everything except the magnetic pickup.
Great info, thanks.
I would think the cap doesn't even need to be installed to do this correct?
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
