Thread: Starting issue
Old 10-26-2018, 07:02 PM
davids2toys's Avatar
davids2toys davids2toys is offline
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
I never doubted you for a moment. Fish the wires through the anti-strain plastic funnel, solder and shrink wrap the connections, and then you might want to just check the timing since shifting the pickup a little bit from the last one can change the timing a hair.
Thank you for the guidance...you were right, pretty easy and I learned a lot!
Are you talking about the pigtail connections? Obviously you must be. Are suggesting I take the wires out of the plastic holders and solder them together where you won't be able to break them apart for trouble shooting or anything else?
Good idea about the timing, if it runs any different, I will do that
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
