Thread: Starting issue
  #30 (permalink)
Old 10-26-2018, 09:13 PM
davids2toys's Avatar
davids2toys davids2toys is offline
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Yes, I generally do that unless the circuit requires disconnecting/connecting on a common basis. It's just too easy to cut the wires when you need to, then solder and shrink wrap them back. You never have to worry about a "jiggly" connector or a connection that is prone to unnecessary resistance when it's just a straight soldered connection.
I do see your point but soldering and electrical is not a natural for me. I think I will just make sure the connection is clean, tight, and loaded with dielectric grease. I really should practice soldering, I have all the stuff to do it.
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
