Thread: Valve Gapper
Old 10-28-2018, 06:18 AM
HTM101 HTM101 is offline
Originally Posted by Gaz64 View Post
That's a nice piece of gear.
Does the little piece at valve no 3 keep the rocker back towards the lifter, so you can sneak up on the final figure, and then recheck by hand?
Yes. It's spring-loaded and keeps a constant lift between the retainer and rocker tip, as you're adjusting downward. It doesn't interfere with the roller tip and the valve stem. I did several hand measurements with a feeler, and realized it wasn't necessary as the tool is so accurate.
