Old 10-29-2018, 05:05 AM
Ron61's Avatar
Ron61 Ron61 is offline
If the sound is so low it may be doing it when you are driving and you just can't hear it. That sounds as if it is getting a low voltage feed from somewhere. If the switch is good then check the hot lead to your horn and look for some place it may be touching a wire that is hot all the time just enough to let some voltage through. A relay sticking would normally let the full voltage through but that is another easy thing to check so don't ignore it.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
