Thread: Starting issue
  #32 (permalink)
Old 10-30-2018, 02:16 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Yes, I generally do that unless the circuit requires disconnecting/connecting on a common basis. It's just too easy to cut the wires when you need to, then solder and shrink wrap them back. You never have to worry about a "jiggly" connector or a connection that is prone to unnecessary resistance when it's just a straight soldered connection.
Yes that little connector is the most common issue for failure in MSD.
Rubbish pins.
I would replace them with gold plated pins (Male & Female), and run a shielded harness.
