Old 11-02-2018, 09:49 AM
cycleguy55's Avatar
Originally Posted by MOTORHEAD View Post
Thanks for the replies!
My aluminum block 427 has been intermittently overheating and belching out enough water to cause an overheating condition for the last 6-8 mo's. Had to trailer it for the last day at our "Reptile Roundup"and drive the the tow vehicle .
I'm running a 13# cap, which I though was too low, so I called David K, and he said "don't go higher, you'll blow the radiator", so I changed out the 'stat. No joy, still o'heating.
"For most cars, the normal operating engine temperature is in a range of 195 to 220 degrees Fahrenheit..." https://www.cars.com/articles/should...1420680334271/
Given the 'normal operating engine temperature' referenced in the linked article, anything up to 220°F is normal. If you're running typical coolant concentration (e.g. 50/50) in a pressurized system, boiling temperature will be 240°F or higher. I saw 250°F on mine when the cooling fan relay failed and, while it puked out some coolant, there was no damage or lasting effect.
Coolant expansion, of course, is to be expected - hence the design and naming of the Ford FE expansion tank. As such, puking out coolant may be more an indication of over-filling than overheating. How hot is it getting? What is your thermostat reading when it's 'overheating'?
Whenever I run across cooling issues (mine or others) I turn to these Tech Tips: http://stewartcomponents.com/index.p...formation_id=6
Brian
