Old 11-04-2018, 04:49 PM
tortuga tortuga is offline
Default Thompson accelerator nozzle plates
Took the plunge and installed, noticeably smoother tip in and better pull out of the hole. Probably reduces top end a touch due to a bit of air restriction, but with 540 odd HP that doesn't occur much, and when it does not for long...I went down to 25 on the front side, smooth as silk. Use nozzle type squirters, had to bend them slightly down to get them through the holes. They spray right on the back of the plates nice flat sheet of fuel...
Steve H
SPF 1764
Superformance 1764
Built 427W
Aiken SC USA
