Old 11-05-2018, 09:21 AM
tortuga tortuga is offline
Default Good point
Originally Posted by Gaz64 View Post
The manufacturer claims that you can't fit them to shooter style nozzles.
Good to see you can, and good to hear of a happy result.
Only gripe I have is what the part does to the signal at that area of the booster, and hence fuel distribution leaving the booster tail.
Gary
Suppose it's a bit of a trade off smooth low end vs unobstructed high throttle flow, kind of think the secondary side wouldn't really need them...haven't opened her up that far to see (feel) a difference...
The nozzles really make them work, normal squirters are a bit of a hit and miss affair, some in the holes some out...the nozzles have to be carefully bent juuusssttt enough to pop through the holes, makes install easy as the whole thing is one unit once the nozzles pop through (per the instructions you no longer use the lower gasket...
Thinking about it, I wonder why you wouldn't make the squirters spray more of a misty fan shape like the windshield washers on our Chevys?
Steve H
SPF 1764
Superformance 1764
Built 427W
Aiken SC USA
