Thread: Fuel Issues
Old 11-05-2018, 09:48 AM
Frank Messina's Avatar
Frank Messina Frank Messina is offline
Cobra Make, Engine: FFR, V8, Manual Trans, Htr, Wipers, Radio Delete
Looks like somebody got carried away in the fuel supply department. There is no need for two electric pumps but since you do have them they need to be fed separately from the tank and the output combined via a -10 Y to the main supply line to the front. If they are in series you will have another supply problem if one quits. If you intend to keep both the mechanical and the electrics the electric pump(s) need to run all the time. The mechanical can't pull the fuel through the electric pumps at a sufficient rate to supply the engine's needs.
Frank
FFR - V8, Manual Trans, PS, Inop Wipers, No Radio, Gas Mileage so-so
