Old 11-05-2018, 03:38 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by tortuga View Post
Suppose it's a bit of a trade off smooth low end vs unobstructed high throttle flow, kind of think the secondary side wouldn't really need them...haven't opened her up that far to see (feel) a difference...
The nozzles really make them work, normal squirters are a bit of a hit and miss affair, some in the holes some out...the nozzles have to be carefully bent juuusssttt enough to pop through the holes, makes install easy as the whole thing is one unit once the nozzles pop through (per the instructions you no longer use the lower gasket...
Thinking about it, I wonder why you wouldn't make the squirters spray more of a misty fan shape like the windshield washers on our Chevys?
Steve H
SPF 1764
Yes, any nozzle only achieves some form atomization when it has enough pressure to hit the booster, otherwise it is just a liquid dribble of fuel.
The Thompson plate is closer to the discharge point and hence breaks up the fuel much better.
Gary
