Old 11-13-2018, 02:24 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by tortuga View Post
Gauge reads Zero when ignition is off, fans take it down like they should but not as far as usual, system voltage 12.4 off, ~13.8 running, all connections on ign switch good, batt connections tight, optima red top battery couple years old..
Almost like the null has moved when running? The farthest down I can get it with ALL loads idling at about 950 is about +7 amps...
Battery cranks it right up.
Anyone had similar issue?
I think everybody is reading this thread incorrectly going by Steve's opening statement.
I read it as +7 amps, (positive) not negative, at idle.
