Old 11-14-2018, 02:47 PM
tortuga tortuga is offline
Default So where does it go?
Originally Posted by Hotfingrs View Post
If the wrist pin is in the oil land, you're gonna burn oil. Built a couple big inch small block, burned like a quart every hundred miles. Never showed on the plugs. Last engine I built, 450 inch small block, I shortened the rod length 1/8 inch and moved the wrist pin down so it wasn't in the oil land. Never burned a drop of oil.
So the wrist pin is up in the rings on the piston?? Please elaborate.
Steve H
SPF 1764
Superformance 1764
Built 427W
Aiken SC USA
