Old 11-14-2018, 07:47 PM
tortuga tortuga is offline
Default It's not in the combustion chambers...
Having the wrist pin intersecting the oil rings has absolutely nothing to do with oil consumption. If it did, then every 347 on the road would be using oil....as well as many other longer stroke engines in other engine families. It's a wives' tale and it's one that gets my goat every time I read it.
Oil consumption can come from several places and it doesn't have to be piston ring issues. Valve seals can wear out, valve guides can wear, PCV valves can go bad, intake manifold gaskets can leak.
Some careful investigating will let you know where it's coming from. I'd start by pulling the carb off and seeing if there's oil laying in the plenum. If so, then it's probably something like a bad PCV valve. If you see oil on the intake valve stems, then it could be valve seals or guide wear.
The intake under the carb is spotless...I'm using a walker pcv and a morosso oil catch, looking down the runners (super Vic) no oil, again plugs look great...it's got to be leaking somehow, but not a drip no signs of leaks...maybe a fine squirt somewhere that doesn't drip?
Need to do a real thorough chassis clean and crawl and chase this down.
Thanks
Steve H
SPF 1764
Superformance 1764
Built 427W
Aiken SC USA
