Old 11-15-2018, 12:23 AM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Having the wrist pin intersecting the oil rings has absolutely nothing to do with oil consumption. If it did, then every 347 on the road would be using oil....as well as many other longer stroke engines in other engine families. It's a wives' tale and it's one that gets my goat every time I read it.
Oil consumption can come from several places and it doesn't have to be piston ring issues. Valve seals can wear out, valve guides can wear, PCV valves can go bad, intake manifold gaskets can leak.
Some careful investigating will let you know where it's coming from. I'd start by pulling the carb off and seeing if there's oil laying in the plenum. If so, then it's probably something like a bad PCV valve. If you see oil on the intake valve stems, then it could be valve seals or guide wear.
Sorry to get your goat, but these were on brand new engines, not just one but two. Every part in the engine was new. Burned a quart every 100 miles. Took the wrist pin out of the oil land, and not a drop of oil burned. BTW these were professionally built, not by me.
Jack
XSSIVE .....
