Old 11-15-2018, 07:50 PM
cycleguy55's Avatar
Originally Posted by bkozlow View Post
I too was not happy with the overall light from a pair of Sylvania Ultra visions that I had in, so I bit the bullet and went with a pair of Grote 90941-5 LED. I haven't adjusted them yet and not sure how the pattern is but they are hands down brighter and with a white light, than the sealed beams. There only problem is the cost, $295 for the pair via Amazon as opposed to $353 via Summit. These have the appearance of a normal sealed beam except for the name Grote on them, look at the part on Amazon or Summit and you will see what I mean. Read the directions as far as the connector is concerned, I had to change a couple of my wires on the connector, they give you connectors as part of the bulb. They are very much brighter and their current draw is very much lower than regular sealed beams.
Bill K
Summit: https://www.summitracing.com/int/par...41-5/overview/
Amazon.com: https://www.amazon.com/Grote-90941-5.../dp/B01B1YE02C
These look very similar to the Grote lamps: https://www.amazon.com/AnzoUSA-88103...ASJA8PXPZZTKPM
Brian
