Thread: Mechanic Needed
Old 11-16-2018, 09:00 PM
hauss's Avatar
hauss hauss is offline
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
Default leaking oil
I to had a leaking valve cover aluminum head 351w turned out to be rear main seal and intake manifold. witch required removal of the distributor witch required a brass gear witch required to be timed witch took out the ring gear and starter. Now I work for the shop that did all the work. Good luck to you my friend my leak has been quite the journey. your friend Hauss.
