Old 11-23-2018, 12:03 PM
t walgamuth's Avatar
t walgamuth t walgamuth is offline
Default Tangerine
1. Make, Model and year: VSE built 2002
2. Engine: 350 aluminum block chevy let out to 427 CI..
3. Weight if you know it: 'Bout 2050
4. Suspension type front: Double a arms with coil overs
5. " " rear: solid Winters rear end with four links two angled with coil overs.
Springs if you know it
7. lbs front:?
8. and rear:?
9. QA1 or other :
10. Front compression setting:?
12. Rear compression setting:?
13. rebound setting:?
