Old 06-04-2002, 07:27 AM
Larry Hills Larry Hills is offline
The first time you run the engine let run for 5 minutes or so. Then shut it off & change the oil & filter. Cut the old filter open & look for metal filing. Repeat this cycle until no filings are found. Drive 100-500 miles. Then change the oil/filter & cut open the filter. If you have oil cooler do not hook it up until after you are sure the filings have been filtered out.
Larry K Hills
