Old 06-04-2002, 08:46 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Sounds like your pilot bearing is hanging up a wee bit. Reguardless, before putting a tremec into reverse (or first), pull it into 2nd (or 3rd) first; to stop the input shaft from spinning.
On flat ground, brakes off, in first gear, with the clutch in, engine running: does the car want to creep forward? If so, the clutch is not fully disengaging. I'd bet a sticky pilot bearing though.
