Old 12-05-2018, 01:35 PM
Moriarty Moriarty is offline
Cobra Make, Engine: ERA 427sc
Thread necro!
put a jumper wire from the positive battery cable connection on the solenoid to the front left connection (on the front of the solenoid, farthest to the passenger side). It should crank. If it does, immediately go to the ignition switch and try and crank it. If it doesn't crank, then it's either the switch or the connections between the switch and the solenoid.
Situation:
  • Starter works with jumper.
  • Get nothing when turning the ignition switch.
  • Radiator fan works when manually switched on, but lights do not.
  • No voltage between the Brown and White wires at either the ignition switch or amp meter.
I'm not sure where to trace from here and could use some guidance.
Thanks!
