Old 06-04-2002, 01:31 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Pretty sure you chewed up the distributor gear. If it was a cast iron gear and a roller cam this will happen again. Since the dist is turned by the cam, the motor would have made good noise as the valves smashed into the pistons if it were anything upstream of the dist gear..
